Help Button Misplaced
Julien_SJulien_S Member, csevp Posts: 3 PRO
The help button seems to be hiding the measuring and weight section. Could this be changed?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,958 image
    I have seen this before - I think it is something to do with how you sign in - make sure you sign in to cad.onshape.com (not sso.onshape.com)
  • Matt_LoMatt_Lo Member, Moderator, Onshape Employees Posts: 15 image
    Could you try clearing your local browser cache and hard refreshing your browser (shift+ reload)? That should resolve this problem. If neither of these strategies work, please submit a support ticket.
