Hello, how to display the surface area of this section?
dominique_chaligne
Member Posts: 12 EDU
in Drawings
Hello,
This seems impossible by the mass properties because it only takes into account the parts
NeilCooke
Moderator, Onshape Employees Posts: 5,987
You can either:- Use the Split feature to cut the part in half with a plane (or similar), or
- Create a sketch on a plane and use the Intersect entity to create a fully enclosed sketch face.
Senior Director, Technical Services, EMEA6
Both option will create a planar face that you can select and the area will be displayed in the bottom right corner.
