Twisting a flat bar
milan_jovanovic
Member Posts: 6 ✭✭
Is there a way to twist a flat bar part by 90°?
This is what I would like to get:
Since I don't know how to do that, I have tried by making two separate parts in perpendicular planes, and then using loft to connect them. But the loft is not good, it is not a smooth bend. This is what I get:
Any ideas on how to do that properly?
@milan_jovanovic
In this case, it is easier to build a surface (e.g. mid-surface) of the desired shape and then thicken.
https://cad.onshape.com/documents/6d65f4d492e87677915f2c71/w/27610abb4a5f6028ac9caeb0/e/6b7d1a402efc0db37f58d735
2
A few notes:
- The start/end condition for the loft should be tangent.
- The transition needs to be longer. The example you show has a transition zone that is twice as long as what you've created. This will obviously make the loft/transition more abrupt and less smooth. Create a larger separation between bodies before lofting between them.
- Posting a link to your public document would allow everyone to take a closer look at your issue and increase the odds of finding a proper solution. See here - Forum Post Checklist.
1 -
@milan_jovanovic
2 -
