Locating tab and slots for RHS
aaron_skidmoreaaron_skidmore Member Posts: 34 ✭✭
Anyone know of a feature script or easy way to add locating tab/slots for aligning square hollow tube, at the moment I do them all manually, then mirror, boolean and remove thicken for clearances. There must be a better way!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,983 image
    That sounds like the recipe for a FeatureScript - in many cases all you need to do is replicate  the manual steps. Why not give it a try?
  • aaron_skidmoreaaron_skidmore Member Posts: 34 ✭✭
    OK will give it ago
