Exploded View
GWS50GWS50 Member Posts: 500 PRO
I've just been using the Exploded View command for the first time and notice that the extension lines that are dashed in the assembly are solid in the drawing.
Am I missing a setting somewhere?
    edited October 2020
    @GWS50 I am not seeing this.  Are you showing this as a shaded drawing view?  Are you using a custom template? Is this a new document or an existing?
  • GWS50GWS50 Member Posts: 500 PRO
    Hi Lou
    it’s an existing doc and is a shade view. The ‘What’s new’ video shows a shaded view. It is also a custom template.
    So I have just started a new doc and kept everything else the same i.e. custom template, shaded view etc and the dashed line does show up so I'm thinking that the solid line is because it was an existing document
    Thanks Mike, will do
  • romeograhamromeograham Member, csevp Posts: 749 PRO
    I am seeing this as well (on older existing drawings).
    I'll file a ticket too.
