iPad mouse support
andrew_marsh626andrew_marsh626 Member Posts: 2
I’m trying to use an iPad Pro with the browser app. The only problem I have been having is the scroll wheel on my mouse does not work to use the zoom function. Is there any way to fix this?
  • TimetrekerTimetreker Member Posts: 7 EDU
    The same problem here. I have a Logitech MX Master... with the same problem.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,051 PRO
    If you are using IOS or Android devices, you will need to download the Onshape app from the app store.
    Mobile browsers aren't compatible with Onshape
