Query Explorer feature
kevin_o_toole_1
Hello FeatureScripters!
Learning what FeatureScript's queries can do is often a slow process of reading lots of documentation, and the number of different queries avaiable can be overwhelming during this phase!
To help make this easier, we've made a "Query Explorer" custom feature. This custom feature's dialog lets you play around with Onshape's query functions, using and combining them, and seeing what the results are in real time.
You can add the feature to your toolbar here, or make a copy of the document to play around with its samples.
https://cad.onshape.com/documents/a5d9b2a6211c9576e5747d3d/w/0a149e82759d30f76fc88bb6/e/db0fd8f10a5c8328d3232869
Happy FeatureScripting!
  • TimRice
    TimRice Member, Moderator, Onshape Employees Posts: 315 image
    Did you make this so I stop bugging you and Jake for help all the time? Great feature! Thanks Kevin!
    Onshape, Inc.
  • MBartlett21
    @kevin_o_toole_1
    How does the `convertToFs` function work? I tried opening its document, but it says I don't have permission.
    IR for AS/NZS 1100
  • konstantin_shiriazdanov
    I want to beleve this is some preparation to make possible to feed filtered queries to the native features. But I see you also faced the problem of too long user interface section. If we only had ability to pack more UI options into something like lookup table.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,959 PRO
    Thanks Kevin!
  • EvanReese
    Kevin, this is really cool! thanks. I'm with @konstantin_shiriazdanov it would be sooo helpful for many things to have robust updatable selections built into the model. I'm kind of scratching that itch with my Selection Fillet feature, but the real deal would be something like a "Query Feature" that lets you set it all up, then call the query in any downstream features.
  • EvanReese
    by the way. does anyone have any idea why this document is taking so long in "loading custom features and tables"? it's been spinning for over 10 minutes, and I can't add the feature
  • kevin_o_toole_1
    We're aware of this bug and working on a fix. In the meantime a workaround is to simply refresh the page.
  • john_mcclary
    Oh nice! this should help a lot when trying to debug my fail queries.
  • EvanReese
    got it. I tried another day and it worked.
  • lemon1324
    lemon1324 Member, Developers Posts: 230 EDU
    This is going to be amazingly helpful, thanks for putting this together!
    Arul Suresh
    S1mon Member Posts: 4,615 PRO
    edited November 2024
    Any chance of this being updated? I assume there have been updates to the query functionality since 2021.
    One thing I noticed is that I can't figure out a way to select a sketch feature and a sketch entity at the same time as seeds. There's also no option to create an implicit mate connector as part of the selection process.
    [edit: a quick search of the changelog shows at least one new query since 2021: "FeatureScript: New query for objects on one side of a plane ('qInFrontOfPlane')"]
  • MBartlett21
    Changes in query.fs since 8th October 2020 (FS 1378):
    GeometryType now includes ALL_MESH and MIXED_MESH options.
    New functions:
    • qAllSolidBodies
    • qAllModifiableSolidBodiesNoMesh
    • qHasAttribute
    • qHasAttributeWithValue
    • qHasAttributeWithValueMatching
    • qOpHoleProfile
    • qOpHoleFace
    • qToleranceFilter (marked internal)
    • qSourceMesh with EntityType
    • qEdgeVertex (for getting the edge vertices at start and end rather than having to filter with a qAdjacent)
    • qTangentConnectedFaces with a tangency tolerance
    • qInFrontOfPlane
    • areQueriesEquivalent
    • isQueryEmpty
    • qCoincidentFilter (marked internal)
    IR for AS/NZS 1100
    @MBartlett21
    Good catches.
    The last update was V5 which was in 2021. It references FS 1389, but it looks like they were just starting to update as there's a few commented references to "qSourceMesh", but the rest of those others are completely missing.
    Kevin seems to be at Formlabs now so I'm not sure if anyone at Onshape is actively maintaining this. It is a really useful tool.
  • MBartlett21
    Also fyi, I've done a mirror of the FS standard library at GitHub here. (making it easier to see changes). I also normalised it on the nover branch, taking version numbers out of each studio.
    mbartlett21/fs-std at nover
    IR for AS/NZS 1100
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Member Posts: 1,163 PRO
    Anyone pick up the torch of making a more up to date version of Query Explorer yet? Or am I about to pick up another side quest in my pursuit of sheet metal perfection?
  • EvanReese
