Default Landing Folder
ryan_mcgoldrick47ryan_mcgoldrick47 Member Posts: 93 ✭✭✭
edited December 2020 in Product Feedback
I use a folder called Obsolete in documents I share with stakeholders
So that we can easily view things from past updates without needing to go to versions etc.
Often when they open the document a file from the obsolete folder opens automatically which is dangerously confusing, this is one reason I think a default landing page should be able to be configured by those with permission to do so.
    @ryan_mcgoldrick47 Are you simply wanting an option in your settings to be the default landing page?  In the case of a folder for obsolete things (if this is related to release management) obsolete things are only based on a single version.  Maybe I am misunderstanding your use case.  Can you give me a bit more context?
  • ryan_mcgoldrick47ryan_mcgoldrick47 Member Posts: 93 ✭✭✭
    I mean, I would like to be able to set a tab as the default tab that opens when a document is opened.
