Is there an option to 'Return to the Previous View' (eg, after rotating the view)
Ted_BenderTed_Bender Member Posts: 2 PRO
For example, if you are zoomed in for a particular viewing angle.  Then you want to take a measurement between two close faces, so you click on one face, then rotate the view to see and click on the other face... and then you would like to return to the view from before you rotated.  In other CAD programs (eg, SW), you can return to that previous view, or 'undo' the rotation.  Is there a similar option in OnShape?
    There is not, but I would vote for that... please create an improvement request in the category on the right -->
  • tim_collins196tim_collins196 Member Posts: 2
    I would vote for this too. Seems like an obvious oversight, given the volume of more advanced functionality. I also would vote for more rapid access to named views; something more like the spacebar view menu in SW.
