Section Properties
matthew_stacymatthew_stacy Member Posts: 489 PRO
Has anyone written a feature script or found a free application that calculates section properties (area, second moment of area, etc.)?  Even if I had to export a DXF file of the section profile, that would still be better than a poke in the eye with a sharp stick.
From what I gather Onshape does not currently offer this capability.
    If you use extrude-cut, you should be able to get the properties from the remaining part + face.
    IR for AS/NZS 1100
  • matthew_stacymatthew_stacy Member Posts: 489 PRO
    @MBartlett21, I don't understand.  Please provide an example.
    Suppose I have a rectangular cross section 2mm wide by 3mm tall and I want to determine the second moment of area to calculate bending stress for a given applied load. The second moment of area for that section is
    • I = bh^3/12
    • I = (2mm) x (3mm)^3 / 12 = 4.5mm^4
    How do I get Onshape to provide that result for this example or more complex profiles?
    Any solutions for this?  I can't remember it ever being added.   I was hoping I could use the section tool, then select the sectioned face and get the section properties but doesn't look like that's here.
  • alnisalnis Member, Developers Posts: 453 EDU
    A decent free workaround:
    1. Section feature made by @MichaelPascoehttps://cad.onshape.com/documents/bdffe7bf48f3b4155e85d073
    2. Export DXF
    3. Drag'n'drop to online DXF property calculator: https://acube.xyz/ (free account required)
    Just need to be careful that the units match, but this seems like a "probably good enough" workaround.
