re ordering the custom features?
otaolafr
Member Posts: 113 EDU
Hello,
I saw that we can "sort custom features" that orders them in alphabetical order, and also the "customize toolbar".
but I have not found these two options:
A. re-order as we like the custom features,(something like putting the most used first and the least used last)
B. put a custom feature in the main toolbar.
is it possible to achieve any of this?
thanks,
best regards, franco
thanks,
NeilCooke
Moderator, Onshape Employees Posts: 5,952
Yes - customize the toolbar, then drag your entire custom feature toolbar to the "tools dialog" that opens. You can then drag each feature to a new location. You can use this method to create a custom sort order, but you may have to stretch your browser window reeeeeaaaalllllly wide to fit them all on while you do this.Senior Director, Technical Services, EMEA2 -
otaolafr
thanks a lot!NeilCooke said:Yes - customize the toolbar, then drag your entire custom feature toolbar to the "tools dialog" that opens. You can then drag each feature to a new location. You can use this method to create a custom sort order, but you may have to stretch your browser window reeeeeaaaalllllly wide to fit them all on while you do this.0
