Creating midplanes
aiden_seileraiden_seiler Member Posts: 2
In every other CAD I have used there is always a "midplane" functionality that selects multiple faces and creates a plane in the middle. How do I do this in onshape? I have been manually using an offset plane and calculating the middle, but this is very slow and should not be needed.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,991 image
    You can create a midplane between two planar entities, midpoint of curve or midpoint between 2 vertices.
