Extrude Fill
famadorianfamadorian Member Posts: 390 ✭✭✭
If I select the fill in 3d, then extrude, then it works to extrude the fill
, but if I first select extrude, then select the fill from the features list, then it doesn't work. Why?;)
    The difference is that a sketch is guaranteed to be planar.
    Because one is a face and the other is a feature.
  • famadorianfamadorian Member Posts: 390 ✭✭✭
    I was thinking it could do that, since I can select a sketch feature;)
