Angling squares
ryan_heskettryan_heskett Member Posts: 2 EDU
Does anyone know how to angle a square within another shape? I need the yellow square rotated 45 degrees to the left.
    Try the Transform tool in Sketch (under the Pattern icon) - you can rotate the square and the lines will remain perpendicular to each other.
    or show constraints and delete the horizontal, then constrain one corner (fix or positionally) and rotate. Dimension angle to pin down.
    www.accuratepattern.com
