Threads in Drawings
frank_ringfrank_ring Member Posts: 42 ✭✭
Hello,
Is it possible to show threads in drawings with a 3/4 circle in top view,
or with correctly arranged lines in sectional view?
Thank's for your help.
Frank
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,028 PRO
    Onshape only supports cosmetic threads with holes created by the hole feature.
    External threads you will need to create a cosmetic thread yourself or cut a thread into the part.
  • frank_ringfrank_ring Member Posts: 42 ✭✭
    Thank you John for your feedback
    It would be good to follow the specifications of DIN ISO 6410-1 for thread representations.
    There should be a circle function, so that the 3/4 circle could be represented. A line function already exists.
    They have a working list of priorities.
    The best way to get something moved up the list of important features is to stay vocal about it, get more users to upvote and be vocal themselves, create or up vote improvement requests, or reach out directly through the 'contact support' feature in Onshape.
    By being a pro member your votes have more weight also
  • don_love228don_love228 Member Posts: 1 PRO
    This is sort of why I am not a pro user.  OnShape needs to improve to a pro level system first.
