How to make a simple tapered cylinder.
tracy_evans
tracy_evans Member Posts: 15 PRO
I need a cylinder that is say 40mm diameter on one end and 30mm diameter on the other end.
I can't quite figure out the right technique.
  • marcus_bernstein
    marcus_bernstein Member, User Group Leader Posts: 35 EDU
    I'd start with a sketch of one diameter and include a "draft" in my extrude. You could also sketch the angled cylinder/partial cone from a side view and Revolve it pretty easily, or even chamfer a straight 40mm cylinder.
    Any chance Onshape is looking for interns?
    Philadelphia User Group Leader
    Revolve would be the most efficient way.
  • marcus_bernstein
  • tracy_evans
    Thanks Marcus. I was trying to chamfer a cylinder but I cold not get it working. I've never tied a Draft. I will check that out.
  • tracy_evans
    Tried Draft but that only goes by degree. Ill try the Revolve approach
  • tracy_evans
    Thanks All. Got it working with Revolve.
