Select Loop Shortcut
jkelleyrtpjkelleyrtp Member Posts: 2 EDU
edited December 2020 in General
Hey there,
Long time SW user. I frequently would like to delete an entire shape or loop. In solidworks, you just double click and the entire loop is selected. This is great for fast offsets, fillets, deleting chunks of sketches, etc. It doesn't work like that in OnShape.
How do I select loops faster than
right click -> navigate to create selection -> click create selection -> open drop down -> select loop -> click select entities -> click OK
This has got to be one of the worst antipatterns for something as common as "select the entire square I just drew." I assume there's some keybinding/shortcut that I'm missing, or perhaps a feature script can fill in the gap?
  • EvanReeseEvanReese Member, Mentor Posts: 2,789 PRO
    I share your grievance about the number of clicks required to use the create selection tool. I'd love to see a UI overhaul on that menu which makes it one hotkey and one click. I imagine something like the s-menu that pops up by the mouse and has icons. I don't know of a better way for now. If you're doing an offset in a sketch though, you can click and drag the face (sketch region in Solidworks speak) and it will offset the whole chain.
  • brandon_furtwanglerbrandon_furtwangler Member Posts: 12
    I have dozens of loops I need to remove from a drawing, and this UI workflow is killing me.  It's been over a year from this post, has a shortcut been added yet?
  • pharesphares Member Posts: 15 PRO
    I agree. The current method of doing this is tedious. OnShape could at least add the option in Right Click > Select > Loops
