Help me hollow (or shell) a model please!
Hi, I am very new to Onshape (or any form of CAD for that matter) and have spent the day completely lost I'm afraid!
I am trying to draw a small dust collection fitting, and have what I think is a solid model, although it may well be a series of hollow surfaces at this point.
After much trial and error I was able to make a similar part (version 1) yesterday. The biggest difference between the two is that the cylindrical portion yesterday was an extrude, and today it is a sweep. I have the feeling that the answer is very close but my brain is a bit computer fried!
So basically I have a loft and a sweep that don't want to play. I did get them to work in a fashion by removing surfaces and then thickening, but there were too many bugs to persevere. I have tried to shell to sweep a cylindrical object and pretty much every combination I could think of. There are plenty of errors showing, but I have not been able to find anything to explain what they might be.
If someone could point me in the right direction I'd greatly appreciate it.
The drawing in question is HERE
The drawing that worked for me is HERE
1
sebastian_glanzner Member, Developers Posts: 452 PRO
@bitingmidge I can't make a copy of the document. Can you adjust the share settings? Then I could try to help you :-) Nevermind, now I could make a copy :-)
Here is my "solution". Please note that i changed some of the dimensions to make it work. I also rearranged, deleted and added some commands.
https://cad.onshape.com/documents/dcaf711ab117c5891fde8777/w/7e62b560fb75cc4376590b61/e/29e33e382b67b225c4be5fff
The main problem was/is the loft. Somehow I can't make a thicker shell than 1.4mm. Maybe you have to change the profiles sketches to get a "better" loft.
Here are some tipps for you:
- Make sure all sketches are fully constrained. If you see blue lines, then they are still "moveable".
- Instead of the split feature you can use the boolean command to substract (Make sure to "keep the tools" if needed)
- Use the shell command only for the pipe segments
Use the "Rollback bar" to scroll through the solution. This way you better understand what each feature changed. Also make use of the section view to look for gaps and errors in the geometry.
This is a very complex model for a CAD beginner
You should also check out the learning center, it has great tutorials.
1 -
@bitingmidge
Tipps for your second document:
- Make sure to create a "new" volume when you use the extrude command for the pipe sections
- Use boolean to substract the pipe from the plate
- Don't use too much Split commands
Have a close look in this document, I changed and deleted some features:
https://cad.onshape.com/documents/50ee5212ddabb940cbaeb72e/w/f73cd9c98d92da6a96579342/e/a7503c0dd0bee1b4c95b1771
Regards,
Peter
Peter
