Sub Assembly not Updating
christopher_quijano
OS Professional Posts: 50 PRO
in General
Hello, I hope someone can help me understand what is happening in my model.
I have created a sub assembly (1) with three parts and mated them together with one part's position fixed.
I inserted this assembly into another top level assembly (2) and fixed its position.
I went back to sub assembly (1) and suppressed a mate and then moved the block part around. When I went back to the top level assembly (2) , the part did not move.
I inserted another copy of sub assembly (1) and the parts imported in the new position.
I am sure I am missing something very simple, but can someone explain why the sub assemblies do not update after they get inserted?
Here is the link
https://cad.onshape.com/documents/267e38e71e7ec8813d1249e1/w/a5d001ae4d3ff0da3d68bcef/e/eb06d6bbd8607771ce456237
Thanks,
Christopher
Here is the link
Thanks,
Christopher
1
Relative positioning does not influence an upper-level assembly. The mate suppression did carry over to the upper-level assembly so now in that upper level you can move it around.
Fixing also does not carry to a higher level assembly. This is a more traditional CAD way of doing things.
It looks like you will want to use a Group in the sub-assembly to get the desired result you want. You need something to enforce that behavior such as a Mate or Group.
This will help you: https://learn.onshape.com/learn/course/fundamentals-onshape-assemblies/working-with-an-assembly/assembly-structure
Twitter: @bradleysauln
