Need help on making this
justin_park563
Member Posts: 6 EDU
in Drawings
See the fantastic training tutorials above. Your part is a good basic shape to learn parametric CAD. You will use sketch, extrude add & remove, fillet, draft, and hole features to make it in Onshape. Then create a pattern, have a foundry cast it, and a machine shop to finish.
Also, I made a custom tool that I use for parts like this. Saves a lot of time.
https://forum.onshape.com/discussion/15113/intersect-views-new-custom-feature#latest
First off — you do need to do what @bruce_williams says
See post below for revised part
Edit — There’s one place on the drawing where it shows R13. I didn’t use this. I made things tangent
I changed the order or sequence of the fillets
https://cad.onshape.com/documents/6701e116e28965040f27a469/w/11315e0b587e1f98bba1c252/e/18ae844fd9886ba49143eea5
