Connecting tubes together.
jonathan_sawyerjonathan_sawyer Member Posts: 2 EDU
As you can see in the photo, there a gap created when these three tubes connect/intersect. I was wondering, is there a way to remove this gap? Like make it so that all three tubes connect together smoothly?
  • MichaelPascoeMichaelPascoe Member Posts: 2,536 PRO
    edited January 2021 Answer ✓
    There are lots of ways to do this: Revolve, sweep, loft.
    Here is one method:
    • Start with solid cylinders. This will let you have a clean interior with the final step.
    • Create a sketch of the open portion of the joint.
    • Revolve that sketch and add the new part to the existing parts.
    • Hollow the ends.
    Here is one method:
    • Hollow the ends.
