Drawing - Show Revision Table Icon
matthew_stacy
Member Posts: 487 PRO
Apologies for being daft, but I can't find the toolbar icon to insert a revision table in a drawing. The help (https://cad.onshape.com/help/Content/drawings-revision-table.htm) shows FOUR icons for inserting tables, with one specifically for revision tables. I only have THREE icons: Table, BoM Table, and Hole Table.
Looking for this:
But I only have:
Suggestions?
raj_Onshape Onshape Employees Posts: 110The Revision Table icon is only available if you opt into Release Management and the document is owned by a company0
It would be extremely helpful if the HELP documentation indicated when functionality is restricted to particular subscription levels (public/edu/standard/pro/enterprise). Perhaps it already does and I just missed it?
My first thought is: are you using Release Management? I think that the Revision tables (and functionality) only show if you're using Release Management.
If you are using Release Management, then check with support (because the Revision table should appear) - if not, you can turn it on in your settings (should look something like this):
See if that helps.
Release Management works with Part Numbers (for Parts, Drawings, and Assemblies, and other files) to keep track of the Revision level of each item.
It works well - and the Revision tables do a good job of tracking the Revision of the Drawings. You don't have many options for customizing the tables yet.
Hope that helps!
I really like Release Management - it allows you to manage single parts in Studios / Documents...so that when you Version the document, the places where you used a Revision of a part don't require updating (fewer blue update icons).
