Missing digit when adding sketch dimensions
3dcad
Member, OS Professional, Mentor Posts: 2,477 PRO
When I sketch something and then start to quickly put in dimension with on-the-fly dimension system (line, rectangle, circle etc.); system takes first digit and then third. It always misses the 2nd but not others.
So if I quickly input '1234' I get '134' into dialog.
If I type slowly then it takes all digits.
Not a biggie but very annoying as typing dimension should be fast procedure.
When using dimension tool afterwards it works perfectly no matter how fast I type the numbers.
I have experienced this for long but not always. I'm not sure when it started but I am sure it's happening and I can easily reproduce anytime.
No such problem with any other software, sometimes text might appear late on screen when typing fast but never misses digits like this.
Anyone else with similar behavior?
//rami
