How do I print my 2D drawing the exact dimensions?
dhagash_desaidhagash_desai Member Posts: 2 EDU
I have a 2D drawing. I want to print it the same dimensions as my drawing. It always either zooms in or zooms out. How do I print it?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,001 PRO
    First make sure your printer is capable of printing accurate to scale. And it accepts the paper size your drawing is made on.
    In your printer settings make sure you select the same paper size your drawing is. Then make sure you set scaling to full or 100%.
