Use configuration variable in part properties?
Eleanor_CoffinEleanor_Coffin Member Posts: 43 ✭✭
I feel like there's an easy way to do this that I'm missing... I have a part that uses a configuration variable for its length. I want to use that variable in the description for the part (ideally in an equation) so that I don't have to manually change the description for every instance of the part I have in my assembly, because they're different lengths. How do I do this? It wouldn't really work for me to add a custom property for this part because it would be just a few parts out of a couple hundred that need this specific property.
  • Eugene_RegentEugene_Regent Member Posts: 2 PRO
    The same problem to me too.
    Now I am using Boikon/Bosch alu profiles with several lengths in an assembly as configurations.
    Using Computed Part Properties , mentioned by BLeeVN is only for the mass.
  • John_vd_WerffJohn_vd_Werff Member Posts: 66 PRO
    @Eugene_Regent
    There is a feature script 'Part name FS' from @Evan_Reese that creates Part numbers and/or Part Names based on configurations.
    I created a derived version called 'FS Part Properties' and added the option to create a Part Description based on configurations.
    I have used it for exactly the same situation; creating individual numbers, names and descriptions for configured Bosch profiles of different length
  • EvanReeseEvanReese Member, Mentor Posts: 2,828 PRO
    My Part Name feature was originally based on code from Neil Cooke's Part Number feature. They were both made before computed part properties were introduced, so that might actually now be the best way to do it, but I'm not sure. The example just does the part volume, but I think it can do way more complex things. It does seem like it's mostly there for when you need a company-wide property computer. Otherwise, a custom feature can certainly do it. This makes me think that it might be worth writing a new "Set Property" feature were you can choose any property to set from a dropdown instead of limiting it to Name and Part Number. I might take a crack at it when I have time if no one beats me to it.
  • Jon_HJon_H Member Posts: 37 PRO
    Hi @EvanReese, as you said the computed parts properties is more for company-wide things which is why your script could still be very useful ! Unless I've missed some recent update, this is still the only way to configure properties using variables.
    However it seems like it doesn't fully work anymore, maybe due to the changes in Onshape over the last few years ? I can get the featurescript to change the name of a newly created Part, but not a Part that has been manually renamed already which is a bummer for existing designs or when you didn't plan to use the featurescript from the beginning.
    https://cad.onshape.com/documents/a8577f7874d29d3b03f0c91a/w/c2947d4f544572e122db26b3/e/53836c9b6170f3ff4a99aafe
    Also a small detail but with the addition of the "convert to expression" feature in previously text-only fields, the dialog box is a bit confusing because you have to use the button instead of converting the field like people have gotten used to by now.
    Unfortunately my FeatureScript-Fu is limited to converting and concatenating strings so I don't even know where to start to adapt your script… it would be very appreciated if you could have a look !
    Yeah I'd love to update mine sometime to modernize it a bit. Unfortunately, if you've changed any of the part properties manually, a feature cannot override them. I suspect this is because the properties are computed after the features regenerate, so any change the feature makes is overridden right away. There's a blue button in the part properties dialogue to "Reset part properties" or something like that, which will clear all of them, but make it work with features again. I'd love to see some progress in this area from the dev team, to reset only one property or something.
