Appearance Colours Hex Codes - Do the codes conform to a Standard?
chrisjh777
chrisjh777 Posts: 211 ✭✭✭✭
I have be experimenting with Appearances (trying to emulate the approximate colours of, say, brass or alochrome 1200S aluminium components. I noticed that there is the capability of inserting a hex code for the desired colour.
I found this website that lists 500 colours including corresponding hex codes:  http://cloford.com/resources/colours/500col.htm.
However when I use codes from this site, I get totally different colours.
Is there a list of colours (with associated hex codes) that can be used?
  • chrisjh777
    Hi Peter,
    Thanks.  Codes work fine from your suggested site.  I suspect that the site I found would also work.
    I discovered that when I was selecting the hex code, I was inadvertently selecting the hash character as well.  This made my light yellow colour very turquoise!!
    When I copied and pasted the required code (without the # character), all worked as intended.
    Regards
  • billy2
    billy2 Posts: 2,194 PRO
    yes, but it can't handle FFF, has to be 256, FFFFFF.
  • Wesley_N
    Wesley_N Posts: 17 ✭✭
    Here's another website with color codes and a spreadsheet I made based on the csv file from this site.
    http://www.procato.com/rgb+index/
    http://www.keystonecollections.com/ - Handcrafted Furniture                                   http://www.newswangerpen.com/  - Fine, handcrafted writing instruments
  • _Ðave_
    _Ðave_ Posts: 712 ✭✭✭✭
    Hopefully soon OS will have a standard color palette with custom options like everyone else.
