Curves on pipes
in Drawings
hi,
as you can see in the image, i must to connect hydraulic pipes with curves.. i tried to make a loft but, as you can see, the curve is squeezed. how i can do to make a curve with the same diameter?
thanks
thanks
Maybe it's easier with sweep.
https://cad.onshape.com/documents/4215538f98ccde7fa5c4ad78/w/14fb54a960b28716712d294f/e/bc92ff784a72259044480ce8
https://cad.onshape.com/documents/525452e8e49d41d335285e1e/w/ef85f336a303b23b8d27c775/e/b7af76fa2b9f952815af0e64
very very thanks!
