group & associated mates invert suppression state
Bart_WooleryBart_Woolery Member Posts: 6 ✭✭
edited February 2021 in Using Onshape
It would be nice to have the ability to select the mates associated with a group and the group, right click, and choose "invert suppresion states" or somesuch (you can arrange things in the mate features tree so the group and mates are together which is what I almost always do). the idea being that if you have an active group with its associated mates suppressed so that it resolves, but you change some geometry in the group, you would want to suppress the group and re-activate the associated mates to get things to be in their proper places, then reverse the process to once again activate the group.
    @Bart_Woolery This is a larger issue to how group works and we have a few improvements to address this issue a different way.  Thanks for the input.. we do see enough issues with group messing with the behavior as it is implemented today.
