Best way to determine if a query is "empty"?
brooke_spreen
Member, Developers Posts: 115 ✭✭✭
I often find myself writing something like:
if ( size(evaluateQuery(context, my_query)) > 0 ) {}
Is there a better way? It seems like `qEmpty()` should be useful, but so far no dice....
PS - is it possible to make pretty code quotes in this forum? The option under `Paragraph`>`Code` seems to corrupt some characters...
Design Engineer | Anerdgy AG
1
A query does not contain anything, only when it’s evaluated. The result of an evaluation is an array so you can also do if(evaluateQuery(context, query) !=[])Senior Director, Technical Services, EMEA4
Makes sense, thank you!
Design Engineer | Anerdgy AG0 -
If it is a user selection you are testing you can also use verifyNonemptyQuerySenior Director, Technical Services, EMEA1
Very elegant!
