Use (convert/Project) tool does not convert inner geometry
SamWiseTheGSamWiseTheG Member Posts: 1 PRO
When using the "use" tool to convert lines of a body if you click the face I would expect it to convert all geometry on that face to the new sketch plane, but it only converts the outer perimeter it seems. Is there any way to make it convert all the geometry on the face without manually clicking the inner ones? I know you can use the drag boxes to select them easier than manually clicking, but it would be ideal to just be able to select the face.
Simple example:
https://cad.onshape.com/documents/0b0a3887a1e2effb9c9b8b02/w/7a976b3536fa045278634ba5/e/6eb36a5d1b5932667d8cea01
When hovering over the top face it highlights all the edges including the inner circle, but when you click it, the generated sketch does not contain the inner circle.
  • JoshBarnettJoshBarnett Member Posts: 16 PRO
    I too have noticed this - its time consuming having to convert all inner entities
    Is there an improvement request for this?
    Cheers
    Machine Designer | AXIS7
  • jacques_spillmannjacques_spillmann OS Professional Posts: 72 PRO
    one would hope a simple shift or ctrl click should get us to select the inner entities instead of the outer, not sure there is a request for that yet but that would for sure be useful
  • Alan_GuthrieAlan_Guthrie Member Posts: 8
    +1
  • martin_kopplowmartin_kopplow Member Posts: 1,151 PRO
    I would support an option, too. I do in fact want the outer perimeter only in most cases, especially when there are lots of inner shapes that would only get in the way. Sometimes, though, I'd want the whole thing or just the 'holes', and if there was a simple option to toggle that temporarily, it would sure help.
    • outside only
    • both outside and inside
    • inside only
    Who is putting up a IR for this?
