How to select entities drawn on top of an imge
Hi, I have a drawing with an image (that I'm tracing) but I can't select multiple lines (or anything else) with the usual click and drag method, as it seems to think I want to select the image. How do I use click and drag to select entities drawn over the to of an image?
Thanks, Ian
  • bruce_williams
    Hi @ian_harris952
     What is likely happening, is you are interacting with the rectangle that is used to place & size the image.
    It is best practice to add your image to its own sketch.  Then do the 'tracing' on a second sketch.  The tools should work fine then.
    www.accuratepattern.com
  • bruce_williams
    Hi @ian_harris952
  • Hi Bruce,
    Thanks for the reply, and the tip. Sounds like a simple solution and I will give it a shot.
    You are correct, every time I tried to click and drag OS thinks I am clicking the image as that is all that is under the cursor. I was hoping there would be some setting or something for the image that said "don't select me" or something, or some way to exclude it from the click and drag selection process. But I guess not really necessary if the image is in a different sketch!
    ;-) Ian
  • If the image is in a different sketch, as @bruce_williams suggests, you can easily hide the sketch too, while you're working with other geometry. Of course if it's in a different sketch, it won't interfere with your selections.
