Need help making this
justin_park563justin_park563 Member Posts: 6 EDU
  • wayne_sauderwayne_sauder Member, csevp Posts: 647 PRO
    I would draw one half of the profile and revolve that. Next sketch and extrude a hex on the bottom, then use the hole tool to make the two holes. Finish it off by using the chamfer tool to create the chamfered edges. I would recommend studying the help menu and also the learning center if you are not familiar with the tools.
    edited February 2021
    Dude - if this was set by your teacher then you're on your own my friend!
    There are some good resources on how to create parametric, feature-based models here: https://learn.onshape.com/catalog?labels=["Learning Pathways"]&values=["CAD Basics"]
