Drawing View Properties
andrew_troupandrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
edited September 2015 in Drawings
There are so many elements missing from the Properties window for a Drawing View it's hard to know where to start.
All we have currently is "Scale" for that view
The one I personally miss most often is "Model"
We need to know if the model being referenced is a Part, a Studio, or an Assembly
(and before too long, I hope, what configuration, in each case)
And before long, we will need to be able to re-reference views (and sheets, and drawings) so they point to a different part.
It's frustrating trying to use as it is for real work, without being able to track back to what is being referenced, particularly when there's a problem.
Imagine detailing a bunch of visually almost identical parts, when the views are anonymous.
And sometimes an assembly is visually identical to a Part Studio in the same document.
I guess a short-term workaround for the anonymity is to stick a Note on, as soon as each view is created.
As a shorthand guide to what other elements are missing, I can't offhand think of any Solidworks properties which are never useful, so that's perhaps a useful reference point for the long term.
Hopefully others will comment on what is most critical to them at this early stage.
    After I read your post, I was thinking what is this about? I opened it from frontpage. Then I noticed the category was drawings which made me read it again and now I understand what you are talking about. I don't have that much to say about drawings at the moment, I will get back on this at some point.
    //rami
    @3dcad: Thanks for that. I read your helpful comment in time to go back and edit the title and the first sentence to clarify what I was talking about.
  • don_howedon_howe Member Posts: 136 ✭✭✭
    I was looking for away to crop a view but I don't see any way to do this either. There are a lot of short comings with drawings features and tools.
