Rounding corners
ruben_wardruben_ward Member Posts: 2 EDU
edited May 2021 in Using Onshape
It would be convenient if you could choose to only round the corner of an object instead of an entire edge.
    @ruben_ward I am not sure I know what you mean.  Do you have a screenshot?  You can turn off Tangent propagation but I am not sure I know exactly what you are asking for.
  • PrachiPrachi Member, OS Professional Posts: 262 ✭✭✭
    something like this. I used this to trim with a router. specified distance along an edge.
    @ruben_ward This would probably not be a modification to the fillet feature since what @Fisher showed would be done with a sweep instead.  What specifically are you trying to do?
