Configurations
PAH
Member Posts: 17 EDU
Hello,
I have create a design of a table for my Woodworking students. All parts are in 1 parts studio so that I could relate the geometry. I then created a configuration table of the main dimensions (Height, Width, Length, leg size and skirt width). Each student has different dimensions to make the tables different to manufacture. I then created the assembly and a drawing package of all the parts (8 sheets).
How do I change the configuration so that all drawing pages update to the desired configuration? It looks like I need to change each part in the assembly but that seems tedious. I must be missing something.
Thanks for any help,
Paul
Paul
- I could not figure out how to show a variable on the drawings like Student name so the students do not get them mixed up and I did not want to edit each drawing.
- Then a couple of students wanted lift top designs instead of hinging tops (storage inside), so I thought I should model it to see if the mechanics fit the design. Of course it meant some changes to a few parts just for them so I changed to configurations which I thought should work the same but for some reason it does not.
I am still learning and their is no better way then to try things out so I am just looking for more ideas. Thanks again for your help and if you have any other ideas I am open to them.
Thanks,
Paul
