Configurations & Drawings
I am making a drawing package for my students of a project. I used configuration to create different sizes. When I update the assembly to the configuration for a student the assembly updates and my top level drawing on sheet 1 updates but the piece parts on Sheets 2 & 3 stay at default regardless of the configuration on the parts studio.
1. How do I make all drawings reflect 1 configuration?
2. Is there a boolean variable that I can use to turn on and off multiple features?
3. Is there a way to have a variable for student name that will show up on each drawing page?
4. When I turn off a feature, the feature is not shown on the drawing when updated but the dimensions stay and turn red because the feature is gone. Is there a way to hide dimensions when the feature is off?
I have linked a simple model to demonstrate the problem. Any advice would be appreciated. Change between config 6 & 8 and you will see some features disappear but not on all drawings.
https://cad.onshape.com/documents/89838d5846fc5695e175cf0b/w/53c564797d24cf9e3a352bca/e/f66779b0acef2d440172f4b4
Two additions:
On 2, you can use a check box configuration if manual control is ok. However, I don't think it's possible to suppress features based on a calculated value at the moment.
On 3, it's possible that the "Drawing drawn by" or "Drawing last changed by" options in the note tool will give you what you want.
