Select configuration when importing documents from the cloud
jeff_brown304jeff_brown304 Member Posts: 24 ✭✭
edited April 2021 in Product Feedback
I recently imported an OnShape model into SimScale using the "Import from OnShape" feature.  It worked perfectly, however I was surprised that I was unable to select a particular configuration of the part during the import process.
I designed my part to be configurable so that I could run simulations of each variant.  Unfortunately, it looks like I will have to export each configured variant to a file from OnShape individually then import them into SimScale.  It would be nice if programs that integrate with OnShape's cloud APIs such as SimScale could easily import specific part configurations instead of the default.
    Please talk to SimScale. That is not our code.  Our api does support this so they need to implement that.
