Surface from solid
viktor_paileviktor_paile Member Posts: 3
edited March 2021 in Community Support
Hello, here's this noob's question 1:
Is there a way in Onshape, or indeed in FeatureScript, to retrieve (or query for?) the surface of a given solid? Say, get a spherical surface from a given solid sphere?
- So little time, so much to know!
  • MichaelPascoeMichaelPascoe Member Posts: 2,910 PRO
    edited March 2021
    qOwnedByBody would work for this:
    FeatureScript 1472;
    import(path : "onshape/std/geometry.fs", version : "1472.0");
    annotation { "Feature Type Name" : "test" }
    export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "body", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 1 }
            definition.body is Query;
            const faces = qOwnedByBody(definition.body, EntityType.FACE);
            debug(context, faces, DebugColor.RED);
    RENDERCAD
    edited March 2021
    Here is a neat query explorer feature may help you out: https://forum.onshape.com/discussion/14777/query-explorer-feature
    Also, if you search the forums for "new custom feature" you will find most of my features. Some of the earlier ones have nice notes for someone starting from scratch.
    RENDERCAD
  • viktor_paileviktor_paile Member Posts: 3
    Beautiful! Thanks for the solution and the tip!
Howdy, Stranger!
