Save only the created part after reference
公伸_伴
公伸_伴 Member Posts: 16 ✭✭
Please help me.
   Based on the extrusion, we made a convex and concave fitting part.
 The gap is also made by the function of moving the surface so that the fitting is not too tight.
 I want to create stl data modeled from only one side of the convex and concave, what should I do?
 I want to create data leaving only one side of the sex, convex or concave, but if I try to erase only a part, all the parts created later will be erased with reference to it.
 I want to save only the created part after reference, what should I do?
    NeilCooke Moderator, Onshape Employees Posts: 6,108 image
    Right-click the Part in the Parts list (under Feature list) and select Export.
  • 公伸_伴
    Thank you so much.
  • 公伸_伴
    Thank you so much.
