Unable to figure out why a loft surface following path fails. Shows a preview of sections but fails
eric_bauld
Member Posts: 2 ✭
https://cad.onshape.com/documents/b465a470649ebd2dd8ae4f84/w/61098a39d40798b6c4d537b4/e/388ac10e56e6089584027a16
Trying to get a loft surface to bridge two curves using a path, it looks good in the sections but it shows a red line right down the middle?
I want to add other paths along this surface later on but I cannot get a single path to work. The path starts and ends on the curve as far as I can tell as I used pierce on the sketch to line up the path line.
If I don't have a path on loft1 it generates a surface fine, but I want to define how that surface curves between the two outside curves being used to generate the surface.
I am at a loss trying to figure it out.
