Make Public
2»
  • Alex_KempenAlex_Kempen Member Posts: 252 EDU
    Yep, Neil is right. I guess I just temporarily forgot that document level folders are a thing?
    To explain a bit further, you could also simply make a folder at the document level, then put all of the documents for a specific project into the folder and share the folder using one of the two methods discussed above. This is equivalent to manually sharing each document one by one. If you share a link to the folder, you may also be able to more easily share multiple documents with your students.
    Technically, sharing a folder with a bunch of documents is more work for your students when compared to sharing a single document with all of the respective parts; however, students are hardy souls, so I would say just do whatever is easiest for you.
