Fix UIHint OPPOSITE_DIRECTION glitch in array parameter
George_AndersonGeorge_Anderson Member Posts: 71 ✭✭
edited June 2021 in Product Feedback
When an OPPOSITE_DIRECTION parameter is used inside an array, its location jumps to the next line when you move your cursor over the edit box, causing confusion.
    Will pull in as a bug
