Why does using the hole function make it go all the way through?
matchaPopmatchaPop Member Posts: 4 EDU
So I was using the tapped hole aspect, and for some reason even though the depth of the screw is only 8mm, it chooses to go all the way through. I don't know if this isn't something I have to worry about, but I just need to know for sure.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,971 image
    Do you need to just change "through" to "blind"?
