Subassembly component suppression for Configurations
jmccormick
Member Posts: 40 ✭
For the purposes of configurations, I need to "overload" a subassembly with components. In other words, I need to place bolts in the sub-assembly to populate all possible locations used in the upper-level assembly. However, in the upper-level assembly, I cannot suppress the unused bolts for the different configurations.
Is there a way to allow bolts - in this case - to be placed in optional places depending on the configuration used? The "Assembly Configurations" training video shows the antenna being moved around for different configurations but I cannot figure out how to use that in this case.
Can you create configurations for your sub-assembly? Then, your top-level configuration can just assign the correct configuration for the sub-assembly?0
Humm... I don't know. Let me try that... You are saying that I can select configurations from the subassembly?? (I'm still a little new with Onshape...)0
HA!, you are a genius, @tim_hess427. Thanks...0
Glad it helped!0
