Drill
amir_livneamir_livne Member Posts: 85 ✭✭
Hi
I'm looking fir a way to build a drill with that kind of edge
I build it before in Solidworks and I'm tying to do it in Onshape
I'll appreciate if someone can help me
Thanks
Amir
  • MichaelPascoeMichaelPascoe Member Posts: 2,818 PRO
    Does the surface of the cylinder need to have this bump?
    The cuts in the cylinder will be easy, but the bump may be difficult.
    RENDERCAD
  • amir_livneamir_livne Member Posts: 85 ✭✭
    I'm talking about that edge
    edited May 2021
    Try this:
    • Create a plane normal to the cylinder where the end cut is going to be
    • Sketch a spline tangent to each side of the helix flute
    • Split the surface of the bit with the tangent spline sketch
    • Loft remove the split surface with the flat area of the flute (Make sure the flat profile end condition is set to tangent)
    • Circular pattern the swept cut and the loft for a two flute bit
    https://cad.onshape.com/documents/327ed21905722905d88ed7ae/w/70f597a06a728129fda7674a/e/276d29414660422f0aaaec4d
    RENDERCAD
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,991 image
    Unless you manufacture drills for a living, the accuracy of the runout shouldn’t be that important. Drills are manufactured using a grinding wheel set at an angle so there is a leading and trailing edge to consider that is difficult to achieve using a simple sweep. SolidWorks does have a solid sweep feature that will replicate this geometry (and little else). Onshape does not. If you have the profile of the flute correct then a simple extrude normal to the end of the helix should give you a good approximation of the geometry.
    Thank you
    here is more or less accurate approach with attempt to simulate solid body sweep, not very stable though
    Me - "Bows humbly before the masters of Onshape" @NeilCooke & @konstantin_shiriazdanov
    RENDERCAD
