Is it Possible to Rotate / Tilt an Existing Plane and Drawing?
jeffrey_hawkinsjeffrey_hawkins Member Posts: 22 EDU
I've just completed a drawing, and realized after the fact that the whole thing needs to be tilted about 10 degrees relative to the rest of the part. Is it possible to select an axis and rotate the plane is-is?
Thanks.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,985 image
    You can either edit the plane and change how it was defined or edit the sketch and use a mate connector instead of a plane. Please see the help on how to do this.
