Frustrating inconsistency with "Edit in Context"
![robert_mangas](https://cad.onshape.com/images/placeholder-user.png)
Hi all, new here, new(ish) to OnShape, not really new to CAD but, er.... rusty, shall we say? ![:) :)](https://forum.onshape.com/resources/emoji/smile.png)
I'm working on a project for a friend and am having a really frustrating time with "Edit in Context".
Here's the project: https://cad.onshape.com/documents/0f464fcb4e9b648fcc5a0730/w/9472cabe816bdd29cb97b119/e/81d2b98f01d766cbdbeb8c4a ; at this point I'm working on the "Update Bolted" assembly and the PS2-Updates part studio.
The assembly will be bolted, and I had tremendous early success with passing a bolt pattern from one part to another- in this image the two pairs of holes were originally made in "Transom Mount Left" (silver) and then passed to 'Extension Angle Left" (blue) via "Edit in Context". It worked exactly as expected and generated perfectly matched holes. Cool....
![](https://us.v-cdn.net/5022071/uploads/editor/j4/mrrktz12w5od.jpg)
![](https://us.v-cdn.net/5022071/uploads/editor/gj/k1gnf701m6rw.jpg)
![](src)
Then I tried to use the same exact technique with the 4 vertically-arranged holes on the other flange, only to fail miserably. Here's sketch 9 on the inner face of my Motor Mount Board, made by the "Use (Project/Convert)" function on the hole edges from the "Transom Mount Left"
![Image: https://us.v-cdn.net/5022071/uploads/editor/h8/1c58lr5dg587.jpg](https://us.v-cdn.net/5022071/uploads/editor/h8/1c58lr5dg587.jpg)
Then I try to extrude-remove using that sketch to drill the hole pattern in the "Motor Mount Board" Note the input requirement for "Merge Scope"; this was not a requirement for the previous hole transfer/drill operation and is the crux of the issue- I cannot select anything on the screen as my context:
![Image: https://us.v-cdn.net/5022071/uploads/editor/0l/64xahcj5d57k.jpg](https://us.v-cdn.net/5022071/uploads/editor/0l/64xahcj5d57k.jpg)
The resulting error is "Extrude 11 did not regenerate properly: No merge scope selected".
Going back to the sketch that did work, there is a clear difference between the sketches:
![Image: https://us.v-cdn.net/5022071/uploads/editor/8f/d7nyg5b9d8yw.jpg](https://us.v-cdn.net/5022071/uploads/editor/8f/d7nyg5b9d8yw.jpg)
...but I'm not sure how I got the functional sketch on the "Face of Extrude 3" while the non-functional one wound up on "Face of Context 2" as I believe I followed the same workflow.
Where have I gone wrong (as I so clearly have
Thanks in advance,
Robert
![;) ;)](https://forum.onshape.com/resources/emoji/wink.png)
Thanks in advance,
Robert
First, the workflow for both operations was the same- edit the to-be-drilled part 'in context' and transfer the hole sketch from the previously drilled part. Worked great the first time, not at all the second.
Second, I can find no way to "unghost" the in-context part. I can unhide the motor mount board in the Part Studio but the in-context assembly is in a different position entirely, so that if I select the motor mount board as my scope in the part studio the extrude-remove fails because the extrusion doesn't touch it.
