sketch offset with inner + outer corner fillets doesn't work as expected
UlrichHanischUlrichHanisch Member Posts: 11
Hi all, I've created an L shaped extrude with fillets at the inner and outer corners of the L shape. Then, I've added a new sketch at the front face of the L and I've tried to use offset function to get the L shape, but with 1mm offset to the inner of the contour. Onshape creates the offset, but ignores the radii from the outer fillets. Why this? And: how to fix it?
https://cad.onshape.com/documents/29bfd00f1d7012e13390f9d7/w/41ffd2aa6fd8e281a57d6a60/e/c347b74f3d61ba22095fc876
  • shawn_crockershawn_crocker Member, OS Professional Posts: 931 PRO
    @UlrichHanisch
    Did you fix it?  I'm seeing offset radiuses in the sketch when I view your document.
  • UlrichHanischUlrichHanisch Member Posts: 11
    I've tested again right now, but no chance to fix it. Actually, there's a Skizze 2 in the PRT and when change the offset dim from +2 to -2 and back, you'll see, that there's no chance to get a correct offset for the whole contour.
    It was identified by support as being a bug, and hopefully, it will be fixed :-)
