Spurious Interference warning when adding three solids together
Hi, I'm making a part by adding together three solids that mutually overlap. For the first solid I chose "New" and for the other two, I chose "Add" and set the merge scope to the first one. When I do a cross-section, the overlap with the base solid seems fine, but the overlap between the two added solids is highlighted in red.
I think I can just ignore this, but I'm wondering if there's some way to tell OnShape that this overlap is intentional?
