Can't seem to extrude shapes if they share a point?
Cobalt_Echo
Member Posts: 31 ✭✭
Honestly, I'm not sure how to explain this, so I've attached a picture that probably explains this better. I can extrude either ONE of the two shapes, but it wont let me extrude BOTH.
Doc: https://cad.onshape.com/documents/195c5cb7be647ed6d778a16e/w/4e7ad5fb64271a128f3dd9e0/e/2d72f4040d431afc617a558b
alnis Member, Developers Posts: 452 EDUThat is what is called non-manifold geometry. Onshape's modeling kernel, Parasolid, does not allow such geometry. You'll find the same error in SolidWorks, Solid Edge, NX, and any other CAD system that uses Parasolid.
A good way to think about why that sort of edge is not allowed is what would happen if you added a fillet? Would the two blocks join, or would they be separate?
Also, when you manfucature this part, will there be a small gap or a small amount of material joining the parts? This sort of perfect edge shared by four faces is not possible to manufacture.Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.0 -
imants_smidchens Member Posts: 63 EDUif you'd like to potentially save time in the future with similar modeling situations, you can use this featurescript:
https://cad.onshape.com/documents/95c00401c440b44ad8799ef5/w/1f1ebce01a3b8eb6fa102975/e/a7c66fe2275987e0c4b83b9a
just keep in mind this will generate two parts as though you extruded each section one at a time.1
